CAT Attempt Strategy: How Many Questions Should You Attempt?
Started by mycampusreviewofficial, Today at 06:11 AM
The CAT is not just about solving questions; it is also about making the right decisions under time pressure. A good CAT Attempt Strategy focuses on balancing attempts with accuracy. Instead of trying to answer every question, candidates should identify questions they can solve confidently within the available time.
How Many Questions Should You Attempt in CAT?
There is no fixed number of questions that guarantees a good score. Your ideal attempts depend on question difficulty, accuracy, and time management. A practical strategy is to divide the section into three rounds:
Round 1: Easy Questions
Start by identifying straightforward questions that can be solved quickly. Attempt these first to secure marks and build confidence.
Round 2: Moderate Questions
Move to questions that require some calculation or reasoning but are still manageable within your time limit.
Round 3: Difficult Questions
Attempt difficult or lengthy questions only if sufficient time remains. Avoid spending too much time on a single question.
Practise Your Strategy with CAT Mock Test 2026
A CAT Mock Test 2026 from MyCampusReview can help you develop and test your attempt strategy. Take mocks under exam-like conditions and record your attempts, accuracy, time spent, and skipped questions.
After every mock, analyse:
Which questions consumed too much time?
How many attempts were accurate?
Which section needs improvement?
Which questions should you have skipped?
Did you change answers unnecessarily?
Final Strategy
Rather than targeting a specific number of attempts, focus on high-quality attempts with strong accuracy. Regular mock practice and detailed analysis can help you understand your personal attempt limit and improve your CAT test-taking strategy.
Also : cat pyq
