It's always nice when you have a tool that makes a job a lot easier.  Sounds like you are quite impressed with the new scanner, I'm sure with you affinity for older iron it'll be handy often.
Quote from: Firm on Jan 17, 2026, 11:14 PMDTS continues to be a PITA...Started throwing codes for the Secondary Air Injection System, which really is just a complex way of blowing clean air into the catalytic converter for 30 seconds on a cold start to activate the catalyst. So no impact to the way the car runs, but I don't like looking at CELs, so I messed around with it today.
I was prepared to locate, disconnect, and test each component of the system, but the Launch X431 Pro scanner I got a few months back was super handy for this type of work. Using the scanner, I was able to command each component of the system on/off individually with the engine off (ignition on); turn the air pump on/off, solenoid open/close, relay open/close, etc. Doing so allowed me to isolate the issue to the check valve and without even getting my hands dirty. Ordered a new one ($180) and should have it mid-week.
Awesome!! Technology to the rescue!
As a follow up on that DTS Secondary Air System code - the new valve solved the problem, been driving it a couple weeks now without anymore codes. Relatively cheap and easy fix.
Gave it a good wash, wax and oil change today. Yes, it's been a PITA recently, but to put things in perspective, I paid $3500 CAD for the car in July 2018 with 120K kms on it. It's been my primary daily driver since, and while some years it didn't see a ton of miles, especially through COIVD WFH and the car reviews I used to do, but since moving it's been doing my 80km/day commute probably 4-days a week for close to 3 years now. 193K kms on it as of today. I really haven't put much $ into it, maybe $2K (excluding oil/fluids) in parts, most of them being 1-set of tires, 1-set of brakes, and then the more recent repairs I've done.  Looks perfect inside and out, drives great, zero warning lights, every features works like new.
That is such a sharp looking Caddy! All things considered, its been pretty solid for you too.
A little bit of snow in the background?
Sounds like that car has been a great find for you!
$3500 is crazy cheap! At some point it becomes more about the time than the money, but it doesn't sound like you're there yet.
Quote from: Gurgie on Feb 09, 2026, 09:46 AMA little bit of snow in the background?
Yeah, we got this 'snowcrete' kinda stuff....like 4" of ice pellets that became 4" of straight ice. Fell like 2 weeks ago and there's still some hanging around despite temps in the +10-15C range. Kids were off school for a week and a half because they couldn't get the roads cleared...
Quote from: Firm on Feb 08, 2026, 10:29 PMAs a follow up on that DTS Secondary Air System code - the new valve solved the problem, been driving it a couple weeks now without anymore codes. Relatively cheap and easy fix.
As always, good work!
I saw a lovely burgundy color DTS yesterday!
Finally got my trailer hitch on my BZ. It's one of those completely invisible dealios. Receiver is stainless steel. Price was gross. I'm at about $1200 all in.
https://youtu.be/EoKF_EKdzws?si=3m7mzy9S44RlOEav
On a side note, I asked the hitch installer what the absolute nightmare car is for a hitch install. Dude didn't even think for 1 second: Jaguar F-Pace. Says you had to tear the car apart. 1.5 DAYS labor. 😳
Lol, I believe that on the F-Pace. I did a hitch install for a friend once on a small Mercedes SUV....GLA, GLB, something like that, it also absolutely sucked.
Holy crap, I've only installed hitches on vehicles where the hard part was trying to get the solid steel, Class 4 or 5 hitch into place as it weighs more than a subcompact car. Thats ridiculous that putting in a hitch is that difficult.
2020 Toyota Tundra, 2021 Lexus GX460, 2018 Kawasaki Versys 300X
Seafoam
Current cars , 23 Civic, 24 MX-5,16 Tacoma
