Firm's 2001 XK8
Started by Firm, Oct 04, 2026, 10:22 PM
First day I had to work on this since getting it and giving it the initial wash, so I decided to tackle the front strut mounts...these were the worst strut mounts I've ever seen, all of the insulator material had turned to dust and basically just blew out of the mounts, so they were metal on metal, and the strut had about 1/2" of play at within the mount. Driving it, while possible, was very unpleasant with constant heavy clunking, and a really weird sensation / disconnection in the steering wheel as the struts moved around freely.
Turned out to be a pretty cheap/easy fix. Apparently aftermarket replacement mounts are really poor quality, so someone from the Jag forum rebuilds them with their own upgraded setup. $225 for the updated units, and took me about 4 hours to swap both sides. Fairly straightforward work, other than having to use spring compressors, which is always kinda nerve-wracking....but I didn't die. Car drives 100% better now, no clunks, steering feels nice now.
Gotta deep clean the interior (it's nasty) and go to the DMV to get plates, then I'll commute in it a day or two a week while I get the cosmetics finished up. Don't think it needs anything else mechanical right now, but regular usage might reveal some needs, we'll see. It's prime convertible season here right now too, so might as well enjoy it.
There's suppose to be rubber in here....
Front end now sits correctly with new strut mounts...the old ones had collapsed and dropped the ride heigh about 1"
Current Fleet: 78 MGB, 81 380SL, 84 Camaro, 85 Trans Am, 96 Firebird, 96 Firebird Formula, 00 GMC Sonoma, 01 XK8, 03 SLK320, 04 Maserati Spyder, 06 Escalade, 07 DTS, 10 XKR
Great work!! Those spring compressors are scary to use, with the amount of wrenching you do, a wall mounted one in your garage might be a worthy investment :D
No space at the moment, though I'd love one. Garage is absolutely full, but we're inching closer to being able to build that shop in the yard...Once that happens I'll start investing in some better equipment. I want my own tire machine & balancer, a proper A/C recovery machine, etc.
Quote from: Firm on Oct 26, 2026, 09:00 AMNo space at the moment, though I'd love one. Garage is absolutely full, but we're inching closer to being able to build that shop in the yard...Once that happens I'll start investing in some better equipment. I want my own tire machine & balancer, a proper A/C recovery machine, etc.
Nice!! Looking forward to that build ;)
Continuing to plug away on this. Scrubbed the interior yesterday, was absolutely filthy, but it's coming up pretty nice. Front seats and center arm rest need some love with leather crack filler and dye - which I've been working on but not done yet.
At 70mph+ it's got a strange variable frequency vibration in the front end. Had the wheels all road force balanced to rule that out, even though I wasn't counting on that given the variable nature of this. Everything steering/suspension wise visually looks fine, but checking for play on the LCA bushing and found quite a bit...way too much actually. New control arms are not available, so I've ordered new bushings and a bushing press tool, will try my hand at pressing in new bushings and hope that takes care of the issue.
Been driving it on local errands though, and it makes quite a nice beater.
Nice!!
Hopefully pressing bushings isn't too much of a PITA
