What Did You Do To Your Car Today?
Started by Firm, Jan 05, 2025, 01:51 PM
Quote from: Firm on Today at 03:13 PMYep, those civics hold up. Once they started throwing turbos into the pedestrian models, I can't see them lasting like the older ones. As for the oil leak, I'd do a good check to make sure it's not something easy like a valve cover or oil pressure sensor, assuming it's not, then yeah, Blue Devil.
Ya, checked those out Firm.  Can't see anything coming from above at this point. Specifically checked the oil pressure sensor and valve cover. Weird thing is, there's an inspection plate and when removed you can see the engine/bell housing mating surface.  Totally clean inside there.  I dunno, it'll become apparent at some point.
Blue Devil ya'll say?  I'll give that a go.
